Subwoofer making a random noise
14 Dec 2004
South
Just randomly when watching things, the sub starts to output a rumble, doesn't seem to be linked to doing anything, just completely randomly. Not noticed it watching films on blu ray player yet, only when on TV feed.
Ages ago the auto on/off failed, so I just have the switch to on.
Bit awkward to know if it's the amp or the sub. Guess more likely the sub if the auto on/off had failed, maybe some other circuitry is failing?
It won't stop making the noise unless I turn it off then on, then it's ok.
Can't remember fully, but if I unplug the amp feed, it stops, can't remember if plugging it back in it starts again. I'll have to test again.
Don't have any spares to swap out and it's expensive to buy and hope! Lol
Try another source and cable leave it for a few hours playing, if it's ok then it's the amp, or old cable.
If it still does it then it's the sub.
Don't plug or unplug with things poweered up.
Oops, just did it....it stops and does not start again when plugging in.
But it seems to be quite frequent now.
I'll have to get a new cable and try that.
I was rummaging around the back of the amp and that seems to make it make a noise.
Will wiggle the cable and see if it does it more.
Don't have any other sources to put into the sub either, which makes it's awkward.
The only sources are ARC from TV and HDMI from blu ray player and they both do it.
Think this was the cable, moved the amp and it made the sub make a hum, fiddled with cable, no longer doing it. Have a spare cable, that isn't long enough...typical.
Will buy a new one, but its not made the noise since.
I had this years ago - it ended up being a computer connected via HDMI to the AV amp which was causing some weird interference.
I tried isolators, I tried heavy thick cables and ended up changing the graphics card in the machine.
Just thought I'd share.
