Such a cute GPU :)
Man of Honour
19 Oct 2002
Surrey
I didn't realise you could get dedicated PCIE GPU's this small. It came in a small thin client device to extend the number of screens to a total of 6.
AMD Radeon E9173 PCIE
"Lexa" core
GCN14
14nm die
2gb VRAM
3 displayport (1 full size, 2 mini)
Pixel Rate: 19.50 GPixel/s
Texture Rate: 39.01 GTexel/s
FP32 (float) performance: 1,248 GFLOPS
FP64 (double) performance:78.02 GFLOPS
I've not tried it yet bu allegedly it's OK for basic gaming. I will try gaming on it if I get a chance although I don't have a spare copy of Windows to pop on the machine (it's a tiny small form factor thin client system with a Pentium J5005.
Looks like the WX cards, same cooler, but not blue. From the specs, it is equivalent to a 550, which is a 64-bit RX 550. Miles better than Intel integrated, but best at 720p.
Well that's a future project decided then... I have a really old Thinkpad T530 with a quad core i7 CPU and a 900p screen. It also has an expresscard slot and I know you can get expresscard to egpu adapters quite cheaply on ebay. I may have to see how it performs in games.
EDIT: Yes looks like a version of the AMD WX2100 workstation card. I assume Dell (which is the maker of the system I extracted it from) got them cheap from AMD at the end of their life, and used them in their SFF systems to add extra displays.
Such a cutie... come here you!! who is useless??? yes you are...yes you are.. :p
EDIT: its directed at the gpu, just so the easily offended don't have a heart attack.
"Lexa" core
GCN14
14nm die
2gb VRAM
Show us the holes (sockets) in the GPU then....
Its just an rx550. Rx550 came in two variants, they were first seen as a cut down rx560 baffin core which you could unlock and tweak, the other was what you have here, lexa.
