Sucker problem
1 Apr 2003
Northamptonshire
Ive just bought a Snooper Indago (great unit by the way!), but I'm having a rather serious problem with it. WHen I attach the sucker mount to the windscreen it holds for a few minutes, before promptly falling off!
Im pretty sure I am using it correctly, as I borrowed my cousins unit (same model) for a week and used it every day with no problems.
Can anyone advise?
Many thanks in advance!
Joe :)
Or try cleaning your windscreen with someone with a strong alcohol base
[Edit] Whoops, i meant *something not someone :o
Defo clean the screen mate.. the tom tom one kept falling off in the hire car until i cleaned the spot where it was.. it didnt fall off at all after that :D
Also if the mount has a little lever above the sucker, make sure this is clicked down :D
