Sudden APIC instability. Potential causes
18 Apr 2006
Essex
Similar to the thread below started by Thaifood (Potential PSU problem), I have recently had a string of reboots when the PC was literally idling whist watching Youtube videos. Like him I am also wondering if it is a potential PSU problem or possibly CPU related.
System spec:
Ryzen 5700X (UC+UV)
Radeon Rx480 (UV)
ROG Strix B450-F Gaming II
Patriot Viper Steel 32GB (2x16GB) DDR4 PC4-28800C18 3600MHz CAS 18-22-22-42 (running XMP)
Super Flower Platinum King 550W 80 Plus Platinum
The BIOS (50.03) whilst not the latest, is from Feb 2023 whilst the latest is from Mid June 2023. I will run a Windows Memory Diagnostic after work just to check but not certain that is the error as XMP been running since installation. But in the last month, I have had 9 reboots almost all (except one last night when I started fiddling) when watching YT.
As briefly as possible, I run an undervolt and underclock using PBO and Curve Optimiser. Figures are more or less as follows:
-ve offset of -13.125
PBO: -250mhz (so max 4400 Mhz)
CO: (where I have done most of my fiddling)
Core 1: -15
**Core 2: -15
Core 3: -25
Core 4: -10
Core 5: -10
Core 6: -15
*Core 7: -18
Core 8: -25
**Best core, * 2nd best
I was going through the APIC error codes as they occurred and increasing 3mv-5mv when this happening. Most cores where running in the neg 18mv-30mv range. I then thought to move LLC from regular to high to extreme and the random shutdowns continued. I reduced offset from -13.625 to -13.125 to -12.500 and still with shutdowns. I tried running ecomode with offets etc. Still shut downs continued. I am tearing what is left of my hair out. Don't want to run at stock as I prefer cool and quiet and saw volts spiking to 1.41v and temps going to 65C-70C under load (typically 39C-43C or 55 under load).
I will use my PSU checker to check PSU (which is now 6 years old) but has seen a stress free life whilst on usually 12-14 hours daily. I am typically drawing about 75w on HWinfo for CPU and GPU with max of 65w and 99w if gaming (excluding mem, 6x 120mm fans and SSD and 2*HDD) so I would say 200w max.
I am just trying to get a few ideas of what else to look for? Am I being too extreme in my offset? Should I continue to reduce CO values on the APIC errors if they continue to occur? I think that the bulk of the shutdowns occur whilst watching YT point to something when the PC is not under load.
TIA
Noughtboy
System spec:
Ryzen 5700X (UC+UV)
Radeon Rx480 (UV)
Core 1: -15
**Core 2: -15
Core 3: -25
Core 4: -10
Core 5: -10
Core 6: -15
*Core 7: -18
Core 8: -25
TIA
Noughtboy
OK. I ran the Windows Memory Diagnostic and it reported no faults.
However, I now have three incidences if a warning all log within 1 second and all exactly the same as below:
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Unknown Error Source
Error Type: Cache Hierarchy Error
Processor APIC ID: 4
The details view of this entry contains further information. And of course, I am unable to decipher the code generated even in the "friendly view" of the details. Any ideas of where/how to decipher this?
Any time you undervolt or under lock you run the potential for stability issues.
Only way to rule it out is to try stock and see if the crashes still occur
