Sudden change of voltage?
18 Jan 2007
Eastbourne, East Sussex
Hi guys,
Been running my Crucial Ballstix Red Tracer's (4x 2GB sticks) for around 8months now no probs at all.
I havent bothered to overclock it so it sits at the standard 800MHz 4,4,4,12 which when i originally got it i set the BIOS to give it 2.1v
After installing Windows 7 last week (Most likely a coincidence) i started to get bluescreens, immediately triggering me to run a MemTest. After running it it came up with errors, so i set everything in the BIOS back to default including Auto voltage on the RAM. Again i got errors.
Since it can take 2.2v's i figured id give that a shot, test returned with no errors at all.
Should i be worried? Or is something on its way out?
Many thanks for any replies.
