- 10 Sep 2008
- Macclesfield, U.K.
Hi guys.
I built this system last year in June:
500w ocz psu
AMD Athlon 64 X2 Dual Core 7850+ Black Edition 2.80GHz
Corsair XMS2 DHX 4GB (2x2GB) DDR2 PC2-6400C5
ATI 4850
Gigabyte GA-M61PME-S2P nForce 430 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard
HDD 500GB SATA-II 16MB Cache
But it has now started suddenly powering off.
Nothing has been changed or altered.
It will turn on and run for 15 mins then the power goes dead.
Next time its turned on it will get to the Log in screen and die.
Then it dies durring the bios.
And then it wont turn on for a good half an hour.
Durring the 15mins it stays on at 1st i monitored the temperatures n voltages and the temps are all fine and there are no sudden jumps in voltage or anything abnormal and then it goes off.
I re-set the bios incase anythign had changed and it does nothing.
Is it worth me trying a reinstall of windows or testing the sticks of RAM individualy in different slots or does it sound like a PSU issue?
The power light on the PSU (the light behind the clear on/off switch) doesn't go off when it powers down and its doesn't flicker either.
Thanks for any help guys.
500w ocz psu
ATI 4850
