- 3 Feb 2009
So like the title says, my PSU failed, fairly suddenly. The problem is that it's not a complete failure. The PC still boots, gets into the OS, runs a CPU stress test (Prime95 8 threads) and runs various other tests with no problem, but it looks like the 12V rail is running at around 3-3.5V.
I have run an OCCT PSU test which resulted in a complete lockup of the system which obviously points to a PSU failure, my question is; why has this happened?
I have been running the same hardware setup for a year now and nothing has changed. The PSU i'm using is a Corsair TX750W and I got it on recommendation of the members of this forum (obviously I don't blame them but usually when people trust a brand there's a reason for it) and I thought 750 would be plenty for what i'm running. I have an i7 920 runnin at 3.6GHz (has been that way since I got it), a BFG 295GTX and 3 HDD's.
If anyone has any suggestions as to why the PSU would have failed like this so suddenly I would greatly appreciate it. At this point I want to try and figure out if it's worth RMA'ing or just replacing with something even more beefy.
