Hi,
As off last week my PC has been instantly shutting off without warning. This is the log it leaves in the event viewer.
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Event ID: 41
Level: Critical
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
The Details tab displays the following information:
EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
The shutdowns happen approx 30 minutes from restart, regardless of whether the system is sat on desktop or under heavy load.
So far I've monitored temps up until shut downs and seen nothing out of the ordinary, I've also tried swapping out the ram, removing the GPU and running on the IGPU, replacing the GPU with another one, checking for viruses and other nasties, creating a new install of windows and checked all the cables to make sure they are seated properly.
Im currently waiting on a mate lending me his PSU so I can check that, but for the time being I would like to know if there is anything else I can check or any other methods of testing components?
Thanks
System Spec:
Intel Core i7 3770k + standard fan
Asus Maximus Gene V Motherboard
8GB Patriot Intel DDR3 1600 RAM
3GB Gigabyte GTX 780
Samsung 840 Pro SSD
2TB Seagate Barracuda HDD
Silverstone Strider Gold 850w PSU
Windows 8.1
Log Name: System
Event ID: 41
Level: Critical
Description:
EventData
BugcheckCode 0
Thanks
System Spec:
Samsung 840 Pro SSD
Windows 8.1
