I’m putting together my first new build in four years and ideally want to hold on to my beloved eight year old Lian Li PC 60 (What can I say, I'm sentimental about the ol' dear). I’m looking to put in an i7 3770K with a Noctua NH-C12P SE14 and an ASUS 660 Ti DC2 TOP but I’m slightly concerned about air flow as the PC 60 is primarily fitted with 80mm fans (two in the front, one exhaust - in the back - and one in the roof). However, I do intend to install an additional 120mm intake fan via three empty drive bays, install vented PCI blanking plates and modify the case to enable discreet cable management (from manufacturers specifications I calculated an intake of 120CFM and an exhaust of 46CFM).
As I have no plans to perform any overclocking and with the choice of cooler, will this be adequate, if not the quietest, cooling solution? Surely an i7, with a stock cooler, has ended up in countless monstrosities.
I think browsing through a number of galleries that feature extravagant modified cases has made me somewhat paranoid.
As always, appreciate any and all input.
