I currently run a 24/7 Unraid server which is used mainly for Plex, Sabnzbd, Sonaar and five Windows based VMs. It has four 6Tb drives (three for storage, one parity) and a 512Gb SSD for cache. The CPU is a Ryzen 2700 coupled to 4x8Gb of RAM.
I'm investigating replacing the CPU with a more power efficient model. The motherboard can be replaced if an Intel is the way to go.
The VMs are used to run a Java based front end for a database. It is important that these run simultaneously with no slowdown. Plex should have some capability to transcode. These are the only prerequisites.
The question is, is there a suitable power efficient replacement?
