Suggest some fans!
13 Feb 2004
Sealed in my Sarcophagus.
Im kitting out my rebuild with new fans.
I am after 10 fans all 120MM.
All fans will be connected, controlled and powered through 2 zalman fan controllers.
Ideally i want either blue or white LED fans. Price is not really a major issue.
The ones i have looked at are the enermax everest and twisters, but after reading reviews these seem to be very bad. Low air flow and temp controlled so you have to strip out the sensors! style over substance it seems.
I have also looked at the Xigmatek XLF-F1254 White which seem promising. And the 120mm Revoltec RL049 Smoke Grey 4x White LED.
Any other suggestions?
I want a nice balance between noise and power... when doing heavy duty stuff i want to crank them up and know that they are going to shift that air properly! while on low they will be quiet and get the job done.
any decent fan won't have flashy lights.
good makes are Sharkoon or Scthye or Yate loon.
There has to be some good fans with leds in them surely? if not i think maybe someone needs to get their finger out :p
I have 4x 120mm Yate Loon D12SL-124UB, blue led and all uv (blades and housing), quiet and shift a decent amount of air. Also if your buying 10 they are very cost effective at around £4 each.
xigmatek's are decent
i have tried lots of fans and I think these are the best
running at 7v they are silent and have decent air flow
