- 27 Dec 2006
- Northampton
Looking to replace my old HTPC. I had a setup but gave it to a family member who needed more than I did.
It will be used for Youtube streaming, watchin HD films, blue-ray films. This will all be connected through my AMP and then into my speakers.
I have all the bits except the CPU and mobo. I'm looking at the AMD A6-6400K, is this a good choice? What else would you suggest? Budget needs to be as cheap as possible really.
Thanks
Thanks
