Suggestions for a cheap 5.1 setup? (sub £200)
Commissario
17 Oct 2002
Panting like a fiend
Hi
My sister has been bugging me about looking into a cheapish 5.1 system for her, so has anyone got any suggestions?
It's for her living room (about 4-5m by 4-5m).
I was suggested the Panasonic SCHT330 for my parents, its easily had for allmost half the budget. Im assuming you need the lost in one, DVD player, amp and speakers. Well this sounds a lot better than anything else iv heard in the price bracket. Its very good in my experiance of cheaper home all in one kit.
For 200 i was suggested the Pioneer DCS333, i havnt actually heard this though but i trust the guy who pointed me in its direction, my parents wernt willing to spend that much.
thanks i'll look into both suggestions :)
she's got a DVD player already, so the set doesn't need one (although it might be handy if it does), but preferably with optical/co-ax digital inputs (the nephews/brother-in-law like their game systems;)).
the yammy amps have both connections. I use optical for my PC sound card andwas using the coax before i got the DD sound card.
After a lot of research in the last few weeks, we settled on an Onkyo HT-S680 for our mum. It sounds terrific, looks pretty classy, has all the audio/video ins and outs that we need for DTS, etc. It got excellent reviews on a few sites and was just crazy affordable. We paid $300 even for it (£172.50). If you can find a similar model, I highly recommend you check into it. :)
YOu will struggle to get the AV-57 is discontinued.
Denon do a similar package at around the same sort
of price which would be worth looking at!
Andy
If shes already got a decent DVD player, and i means it should be a pretty good one, then ignore my suggestion. I thought you were after the whole package.
Reality Bites said:
i've found it in a couple of places for the £180 mark
If you can find it id go for it :)
Can you let me know where you have found it, if its
not a competitor :)
Cheers
Andy
not a competitor :)
Cheers
Andy
only just seen this....didn't get the mail to notify me :confused:
I'm not sure if it was a competitor now but i found it in a couple of places using google.
Maybe end of line or starting to become that way, but for £180-£200 you can't really go wrong.
theboyrob said:
I picked up a set of Logitech® Z-5400 Digital 5.1 THX Speakers are for the money they are pretty good :)
IMO these are still "computer speakers" so would avoid.
Andy
