Suggestions for cheap VM box
6 Aug 2009
Currently running my two WFH VMs on the signature rig. I thought I might build a cheap system just to use for work. Any suggestions? Only running the usual office software, Teams etc. Currently uses about 20GB RAM and 2 cores per VM.
That looks pretty good thanks, I could have on the motherboard too as I have a spare WiFi card. I also have a couple of spare cases too. Think I could get it down to about £380 or thereabouts.
Part of the reason I chose that board is the bios flashback feature which you can update the bios without the need for another CPU. It may be wise get this feature on which board you choose to get the CPU to work.
I'm going to take a slightly different direction (and maybe a bit late to reply)... can't link, competitor rules etc
What about a 'mini pc' like a MINIS FORUM Mini PC (easy one to find in google etc) or similar... just thinking that it's tiny size might be useful in terms of tucking it away out of the way etc. Little bit more expensive depending on specs but they're also more powerful if you go with the (assuming we stick amd) ryzen 6900hx model....there's cheaper versions too.
Actually there's a MINIS FORUM Venus Series UM773 Lite Mini PC Windows 11 Pro AMD Ryzen 7 7735HS up to 4.75GHz 32GB DDR5 512GB PCIe4.0 SSD AMD Radeon 680M Mini Computer, 2 x HDMI,1x USB4,5x USB ports,Wifi 6,BT5. 2 (you know where lol) with £130 off voucher at the minute.. costs £539.
That's a very good suggestion. I wasn't aware of these thanks.
