- 31 Dec 2009
After getting a lot of advice and help from the OcUK forum a long time ago on building my first computer, I am now seeking some help on upgrading my RAM
Although i know how to build a computer, i have little to no knowledge on how component compatibility works but i did do some research and that my mobo supports DDR PC312800 1600MHz of memory (and i am aware that my current RAM has this spec).
So i went to that category on the OcUK website and with that many options, i am unsure on which RAM to pick. Any suggestions or advice on this?
I use my PC for gaming so 8GB of RAM should be fine and my budget would be £50 max.
Thanks very much for the help
.Although i know how to build a computer, i have little to no knowledge on how component compatibility works but i did do some research and that my mobo supports DDR PC312800 1600MHz of memory (and i am aware that my current RAM has this spec).
