Hi Guys,
I'm trying to build a new PC for around the 700 - 750 mark. My laptops graphics card went about 5 months ago and I haven't had the money to replace it. Now I need a good PC for running VMWare and general gaming @ 1680x1050 / 1366x768. Here are the Specs I've come up with so far:
Q6600
P5K-E/Wifi
4gb (2x2) Corsair xms2 6400
Xpertvision 8800GT
Samsung T 500gb
P182
Tuniq Tower
Corsair HX 620
£737.51
Thats what I've been looking at so far. I've had it suggested that I change the Motherboard for the Gigabyte DS3R which would bring the price down by about £25. I plan to put more ram in later as I'm going to be running lots of virtual machines. I'm also planning to put a 9 series in later once they come out. I could also change the Samsung for the WD AA.. whatever its called or the 750gb F1 if they would be better. I could also swap the ram for OCZ 4GB Kit (2x2048) Reaper HPC at the same price.
So any suggestions? Is the 620w HX better then the 650w TX? How much power will I realistically need with one card? Also, what sort of overclock do you think I could reach using these boards?
Any help you could provide would be great.
Thanks guys,
Aron
Q6600
P5K-E/Wifi
Xpertvision 8800GT
Samsung T 500gb
P182
Tuniq Tower
Corsair HX 620
£737.51
Thanks guys,
Aron
