Suggestions to get my 3200mhz ram to run at its rated speed on x370?
16 Jan 2013
Stranraer
Hey there folks so as the title would suggest i have a kit of trident z rgb 3200mhz cl16 and have been running it fine at 3000mhz for the past nearly 2 years but as soon as i enable the XMP profile for 3200 as soon as it boots into windows it blue screens :(
what would be a safe voltage to use for normal daily use and is there any other settings i should change?
im running the latest bios btw so that isn't the problem
can't wait till my Aorus 2070 Super arrives will finally be able to play my games on High/ultra rather than Medium :)
It's more likely the R7 1700 that's the problem than the motherboard. Mine won't even run more than 3000 even with 3200 C14 B die.
