SUGO CPU FAN ?
5 May 2004
HI GUYS
am going to get a sugo as i have most stuff for it anyways in my huge coolermaster ammo
my only prob is will the stock heatsink fan fit ok from a amd64 3200 or anyone have anything else in theres that may be better
am going to replace the 3 fans with akasa ambers
was thinking of a shuttle but seeing as i got every other bit needed i cant see the point yeah may be a bit smaller but at least the sugo will be upgradable in the future
stock fine for my skt939 amd 64 4000+ fitted fine on my sugo, the swiftech heatsink with a decent fan would be a better option though, and wise move replacing stock fan with ambers, as the stock ones are just too loud
that what you got in your sugo gib (sig)
how much bigger is it than a shuttle
and the new sugo evolution comes with 3x80 fans at stange angle
was gonna pair it with a
foxconn or the asus cm micro mobo
any input u have or pics would be greatfully appriciated mate
thats what i had, minus the mobo in my sugo for all of 30 mins before i took it all apart and moved to a lian li pc7+, the sugo is a little bigger than a shuttle. ive got some pics on my dig cam from the build, will upload them for you tomorrow morning. I used a asrock mobo in my sugo, did the job fine, the only few problems i had with the sugo was having to take the fan on the side off before putting the graphics card in and any other pci devices, and the hard task of wiring stuff up in such a small space (compared to a normal pc case)
you had it in for 30 mins then swapped it all out
did you not like it much then
i understand the evolution now eradicates the prob of taking the back fan off and also comes with a screwing plate on the back for easy access
emu said:
is the lian li pc7+ a sff case like the sugo?
nope its a normal size case, only switched as i didnt like the sugo and the mobo i used. bigjonnyauk - found my dig cam so i'll have the pics uploaded in a bit!
GREAT THANKS GIBB
can i ask why you didnt like the sugo was it just a apperence issue or did you find it flawed in the heat department or probs fitting any stuff
ill be putting in
hyper 580 psu
1 gig ram
1 dvdrw combi
1 6800gs
1 250 gig sata2 hard drive
mobo undecided
thats it nothing else
I'm not sure the Hiper will fit depending on the size of the optical drive. It's quite tight in there.
yeah it does just there is a member on here who has one only have about 2mm room though between that and dvdrw
i think my dvdrw is a short one not sure anyone know
pioneer 110-d
Yes, but that's with the PSU cables turned at an angle that they were never meant to cope with. Those connectors are very long. If you can, I would recommend going for a shorter PSU.
just an update i got a
Antec NeoHE 430W Modular ATX2.0 PSU for this and it fits a dream also just using the stock cpu fan with the 3200 proccy temps come in at 40 idle 47 load which i think is acceptable for a small case and the cramp room inside
i think it is best to get a psu which dosent have a fan underneath as i tried one and it sits to close to the cpu fan and gave higher temps
