Sugo & NV GTX 8800
28 Apr 2006
Northampton
Sugo & NV GTX 8800
Toying with the idea of whacking a gtx in my sugo, Does any know of any 1 thats succesfully done this ? Had a quick google last night but didnt find anything.
any links much appreciated thx
lo m8
you could fit 1 in but u will have to remove the hdd cage
with the hdd cage removed it will then give you just over 35cm
but then you will still need a mother board with the PCI-E Slot
to be on the 1st 2nd or 3rd from the left. the 4th slot will be
blocked by the rom cage.
http://www.tosk.co.uk/8800/
Yea would deffo need to lose the harddrive rack, with my current card in it looks like there'd be 3-5mm clearance on the optical bay with a 12inch card.
