Putting together an i7 920 with asus rampage mATX board and corsair 850W power supply into an SG-01, but the cooler that I got, a very low noise scythe shuriken revB low profile is not up to the task of cooling it in the case-
at full load, its ~80 degrees with the case uncovered, and ~95 degrees with the case covered (for the short bit I let it go that way...)....
I am pretty certain the problem is that the large northbridge passive heatsink of the mobo is not being cooled sufficiently, and there's just a large buildup of hot air around the whole back end of the unit- any coolers out there that people may recommend? or should i replace the 10 mm fan with something that will shift more air? Or is the placement of the power supply in the case is such that i need to reverse the direction of the fan in the power supply?
thanks in advance
thanks in advance
