Sugo SG01 - 120mm mod?
28 Jul 2003
South Wales
Does anyone think it's possible to mount a 120mm fan where the 80mm fan for the hard disk cage goes?
Since my upgrade, i'm having heat issues with the x1950pro blowing onto the hard disk casge and getting very toasty!
not without cutting the case up.
Have you thout about reversing the hd cage fan so the air blows in the same direction as the air from the x1950. So looking at it from the front the air would go back to left instead of the current back to left on the x1950 and left to right on cage causing a conflict of air flow if you get what I mean.
