Suitable AMD CPU upgrade for this motherboard
16 Jan 2014
North Ayrshire
Hey guys , merry xmas
Looking to find a suitable cpu upgrade for this amd board,
ASRock FM2A68M-HD+
Just now it has a AMD A4-6320. Looking to get a bit more power out of if max £100. Also will be upgrading the graphics card to be able to play new titles such as bf4 cod black ops 3 etc. Would these little APU chips be suitable without getting a new GPU?
Looking at something like: https://www.overclockers.co.uk/amd-kaveri-a8-7650k-10-compute-core-apu-w-radeon-r7-graphics-4-cpu-6-gpu-compute-cores-retail-cp-391-am.html
minimum quad core
Graphics was looking at this,
https://www.overclockers.co.uk/giga...graphics-card-gv-n75twf2oc-4gi-gx-180-gi.html
I would go with a x4 860k, it's a good CPU for gaming and is well priced.
If you can get a more powerful GPU I would, the 750 ti is not great for 1080p gaming...
What resolution are you playing at?
I would recommend an R9 380, but if you don't want to spend more I would go with a R7 370 instead of a 750ti.
ASRock FM2A68M-HD+
minimum quad core
For the price of that 750ti, you might aswell get the 950 for an extra £10. Performs abit better than the 370 and its fine for 1080p gaming as I purchased one a few days back for my itx PC.
Ahh, I didn't see the cost of the 950's.Yeah, I'd go 950 if you don't want to spend anymore on a GPU, it is definitely better than the 750ti.
sorry its for a family member, who bought an computer online supposed to be gaming rig, wouldnt run anything, when u looked at it and the amount they spent, i told them to send it back and I will build something much better. But they opted for a GPU and CPU as it was an xmas pressie:S
