Suitable line stats for DSLmax?
19 Oct 2002
Bath
Hi guys i should be bing upgraded to dsl max in the next week or so and am wondering what my line rate will be. Heres my stats from my router.
Operational data report : near end (Downstream)
Attainable line rate : 9016 kbit/sec
Attainable Atm rate : 8544 kbit/sec
Used line rate : 2692 kbit/sec
Fast used Atm rate : 2272 kbit/sec
Interleaved used Atm rate : 0 kbits/sec
Rel. capacity occupation : 30
Noise Margin : 23 dB
Line attenuation : 11 dB
Output Power : 11 dBm
Far end line operational data
relCapacity upstream = 37 pct
noiseMargin upstream = 27.0 dB
outputPower downstream = 11.5 dBm
Attenuation upstream = 4.0 dB
Top speeds I would say, very low attenuation of 11dB indicates a short line. Plenty of noise margin available.
If your exchange is Be* enabled, I'd take a guess you would get around 20-22mb with those stats :D
Ooh sorry to post here but it's relevant!
WHat would you say mine would be? I am connected via a hardwired extension off the faceplate (about 2 metres in length) as the router is in the living room RJ45'd to my dads PC as he has no wireless card.
DSL Status: Connected
DSL Modulation Mode: MultiMode
DSL Path Mode: Interleaved
Downstream Rate: 7342 kbps
Upstream Rate: 764 kbps
Downstream Margin: 7 db
Upstream Margin: 19 db
Downstream Line Attenuation: 39 db
Upstream Line Attenuation: 10.5 db
Downstream Transmit Power: 0
Upstream Transmit Power: 0
I'm on Sky 16MB which was enabled in our area last month so It's still pretty new.
and me! im on be could i get any faster?
attenuation 28.5
snr 6.5
connected at 16535 downstream
i can download at 12/13MB could this be improved? thanks
Not showing off or any thing but if you look my line stats you can take a sort of work out what the top end of yours be like
I am useing cisco 877 adsl router
Modem Version Near: 12.4(11)T1
Modem Version Far:
Capacity Used: 100% 100%
Noise Margin: 5.0 dB 5.5 dB
Output Power: 20.5 dBm 12.0 dBm
Attenuation: 26.0 dB 8.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x9C
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 7660 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_AMR-R-2.5.042_no_bist.bin
Operation FW: AMR-R-2.5.042.bin
FW Source: embedded
FW Version: 2.5.42
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 22818 0 1176
What about mine?
I just got this from the router setup, im on 8mb ADSL-MAX.
Type - Fast
Status - No Defect
Downstream Upstream
Data Rate(Kbps) 8128 448
Noise margin (dB) 6.5 24.0
Output power (dBm) 19.8 12.3
Attenuation (dB) 23.0 11.5
SeanyK said:
What about mine?
Type - Fast
Status - No Defect
Downstream Upstream
Well looking at that you should get min of 16 meg on BEthere
but no reason why you mite not even get into the 19 20 deppending on the small print
For those intrested in Be* you can get a rough idea of what speeds your likely to get by checking out either of these
Linky 1
Linky 2
I found the first link to be more accurate for me though.
BE* are not going to be around my way for a long time :(
my line length is just over 600m and thats not as the crow flies thats the actual length :) i can see the exchange from my house
