Looking for a 22 inch monitor which I could build into a small pinball cabinet made from MDF.
Ideally it needs a very slim bezel and if at all possible, not require de-casing to fit, the dimensions of the cabinet will be governed by the size of the screen so I can make it to fit.
Also need a 4:3 monitor for the back glass but it needs to be wider, than the playfield monitor is when laid portrait (head of the machine are same or wider than the body).
Any suggestions?
Any suggestions?
