Suitable Quiet Case recommendations
16 Jan 2007
Reading
I've been quite happy with my rig since i got it (so happy that i haven't posted anything for about 9 months) but my antec 900 helicopter cooling system is starting to do my head in... could anyone recommend a quiet case that will fit a 8800 gtx, my mate as a sonata case (forgot the name) that is really quiet but the cooling isn't great and it's too small.
dont wanna spend over a hundred.
thanks
I bought an Akasa Mirage (same as eclipse but with a door) and I found the cooling was a little naff but I did have 3 hdd's blocking the intake fan, I put in a scythe kama bay (120mm fan that takes up 3x 5.25" bays) and now my temps are very cool and PC is still reasonably quiet considering I have a 7900GS with a fan on it - I used to have a 6600gt passive before.
Also its an Extended ATX case so wont have any probs fitting a 8800 card, I have about a 6" gap from the end of my 7900GS to my hard drives!
I haven't... but i didn't think i could attach the fans to it since they all have those switches on, is there a way to do it?
