Hi their im going to do a water cooling rig soon when the Corsair 900D comes out and im wanting to seriously water-cool it.
so far my water cooling set up will include
cpu:3970x
gpu: 3x titan
psu: xfx 1250w
fans: 26x scythe gentle typhoons
mobo: Asus rampage iv extreme (2011 socket)
memory: 64gb corsair dominator
ssd: 3x samsung 500gb
hdd: 1x wd 2tb
Radiators:
480 mm (top)
480 mm (bottom left side)
360 mm (front)
240 mm (bottom right side)
W/C components:
Asus Rampage IV Extreme waterblock
2x4 piece dominator ram cooling blocks
ek supremecy cpu block
3x gpu's in serial flow
2x d5 on bitspower dual d5 holder
250mm res
xspc 7/16 tubing 3 metres
22x bitspower black chrome 7/16 fittings
i know its overkill but i want a full water cooled rig
questions:
1.In which order would you make the water flow,i was thinking res/pump,pump,360,480,240,gpu,gpu,gpu,mobo,ram,top mobo,cpu,ram,480 not sure if that will be the best way.
2.Is it too much for a single loop?
Any questions are appreciated
thanks
Josh
cpu:3970x
gpu: 3x titan
psu: xfx 1250w
hdd: 1x wd 2tb
Radiators:
480 mm (top)
360 mm (front)
W/C components:
250mm res
questions:
thanks
Josh
