Suitable SATA II HD for Asus A8N deluxe mobo
20 Oct 2002
hi,
we have Maxtor diamondmax 10 sata II hd for Asus A8N -E motherboard and is unable to boot up or have harddisk corruption
it is a known problem for diamond max 10 with nforce 4 chip.
what harddisk will you recommend?
thanks
Ive got a diamondmax 250Gb sata-II 16Mb and a Samsung 200Gb 8Mb cache sata-II. The Samsung and the Seagate are supposed to be the quietest, but since getting a P180 the diamondmax accesses cannot be heard at all (rubber grommet mounting).
The only issue Ive had with either is that the diamondmax sometimes fails to be recognised in the bios (usuall after changing some setting somewhere) and requires a cold boot.
Ive used western digital (have a 120Gb not connected to pc atm), and they are good imo.
