sum cells depending on colour
6 Jul 2007
Notts, UK
Hi,
Got a spreadsheet with values in red and blue
i want to sum anything thats blue in a cell and anything thats red in another cell
i'm guessing this is probably easy but im a noob :p
Hi,
Are your red values negative numbers and the blue values positive numbers? If this is the case, you can sum using <0 and >0 as conditions.
Rgds
Binty
Hi,
Alternatively, you can use a function such as DSUM or possibly some type of IF statement to test the cell value and only sum if positive or only sum if negative.
I think you need to elaborate a bit on your original request.
Rgds
Binty
