Some of these are listed on this week only others Aren't.
Creative SB X-FI Xtreme Audio Soundcard (70SB057002007) @ £9.95 inc VAT
Creative's Sound Blaster X-Fi Xtreme Audio gives an experience beyond studio quality with MP3 music and movies! Featuring award-winning X-Fi technologies, X-Fi Crystalizer restores the details and vibrance lost during MP3 and DIVX compression, breathing life back into any audio, while X-Fi CMSS-3D expands stereo music and movies into amazing surround sound. Effective over virtually any speakers, including stereo speakers, Sound Blaster X-Fi Xtreme Audio even provides unbelievable surround sound over normal headphones! The low profile design plus digital out for connecting to a home cinema system make it ideal for Media Center PCs.
Warranty: 2 Year Limited Hardware Warranty
Features
- X-Fi 24-bit Crystalizer restores the details and vibrance lost during audio compression, enhancing MP3/WMA, streaming audio and video, TV and radio, DivX and DVD movies
- X-Fi CMSS-3D Surround up-mixes audio and video to 5.1 or 7.1 surround
- X-Fi CMSS-3D Headphone delivers incredible surround sound for movies and music over stereo headphones
- Includes Cyberlink PowerDVD software with DTS and Dolby Digital-EX decoding (via free download) for an unbeatable DVD movie watching experience. (Internet connection required.)
- Easy to use Entertainment Console gives easy setup and control
- Low-profile PCI format with Intel HD compatible front panel connector and digital out is ideal for both standard and small form factor PCs
Only £9.95 inc VAT.
ORDER NOW
Edifier Prisma White 2.1 Speaker System @ £43.99 inc VAT
An audio and visual delight, the Edifier Prisma speaker system is a treat for your eyes and ears! The exotically shaped subwoofer and satellites are designed to complement modern PC and monitor styles, while the white finish will suit contemporary homes. A wired, low profile volume control with red halo effect means the makes adjusting the volume easy, and the built-in headphone and MP3 jacks offer flexible listening options.
- Power Output: RMS 2 x 9W + 32W (THD=10%)
- Signal to noise ratio (amplifier) : =>85dBA
- Distortion: <0.5
- Input Sensitivity:
- R/L: 550 +/- 50 mV (Line-in), 300 +/- 50 mV (AUX)
- SW: 200 +/- 50 mV (Line-in), 100 +/- 50 mV (AUX)
- Frequency response:
- R/L: 190Hz ~ 20kHz
- SW: 30Hz ~ 130Hz
Was [59.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Edifier M1370 2.1 Speaker System - Black @ £19.99 inc VAT
Uniquely designed, upward angled satellites projects sound towards the listeners. Translucent satellite stands provides support, the structure reduces possible interference that originates from surfaces. Master volume and bass adjustment dials located on the side panel of the subwoofer. 3.5mm line-in jack located on the side of the subwoofer for connectivity to audio hosts. 5 inch super bass driver and 2¾ inch mid-range and tweeter drivers provide 27watts RMS audio output. Front facing bass reflex port for enhanced bass audio output. Wooden MDF subwoofer housing enhances audio output and reduces audio resonance.
- Magnetically shielded speaker drivers
- Total power output: RMS 7.5W×2 + 12W
- Signal to noise ratio: 85dBA
- Distortion: 0.5%
- Frequency response: R/L: 200Hz~20KHzSW: 30Hz~130Hz
- Input sensitivity: 450mV ± 50mV
- Audio Input Type: 3.5mm Stereo line-in
- Adjustment: Master volume control
- Subwoofer / bass unit:5 inch (131mm), Magnetically shielded, 4
- Treble unit:2¾ inch (72mm), Magnetically shielded, 4
- Weight:4.1Kg (net) 4.83Kg (gross)
Was £23.99Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Creative Sound Blaster Z High Performance Gaming Sound Card - Retail (70SB150000001) @ £59.99 inc VAT
If you’re not communicating you’re not winning!
Part of the ultra high-performance Z-Series of Sound Blaster® PCI-Express sound cards, the Sound Blaster Z is an ideal all-around gaming and entertainment solution that incorporates all the hardware and software features of the Sound Blaster Zx card and comes with an external high-quality beam-forming dual-microphone array.
When used with CrystalVoice™ the bundled Sound Blaster beam forming microphone creates an acoustic zone and suppresses noise outside it, enabling you to be heard by your teammates with amazing clarity even in noisy environments.
Experience every detail
A signal to noise ratio or SNR of 116dB delivers > 99.99% pure audio, which is 34.4 times better than typical motherboard audio.
Power up
The quad-core Sound Core3D™ audio processor offloads gaming effect processing from your primary CPU, improving your overall PC performance.
Live it, don’t just hear it
The SBX Pro Studio suite of technologies immerse you in awe-inspiring audio so you can experience games, music and movies in a 360-degree true-to-life sound stage over speakers or regular headphones.
Find them before they find you
‘Scout Mode’ allows you to hear your enemies from further away, giving you a distinct tactical advantage in combat.
Gear up for victory
There’s no longer any need to unplug your speakers to connect a gaming headset. The Sound Blaster Z series soundcards all features separate I/O so you can easily switch between hardware without having to unplug any gear.
Go Pro
Supports studio quality headphones and headsets of up to 600 ohm impedance.
Hook up for high fidelity audio
Single cable output to your home theatre system. Enjoy cinematic audio by transforming any source into immersive surround sound.
- Output Level (Full Scale): Front Channel Out : 2Vrms, Headphone (33 ohms): 1.3Vrms, Headphone (600 ohms): 2Vrms;
- Maximum DAC Resolution: Front Channel Out : 24-bit, 192kHz, Headphone (33 ohms): 24-bit, 96kHz, Headphone (600 ohms): 24-bit,
96kHz;
- SNR (20kHz Low-pass filter, A-Wgt), @ 24-bit, 96kHz: Front Channel Out : 116dB, Headphone (33 ohms): >105dB, Headphone (600
ohms): >105dB;
- Frequency Response @ 96kHz: Front Channel Out : 10Hz to 45kHz, Rear Channel Out : 15Hz to 45kHz, Center Out : 10Hz to 45kHz,
Headphone (33 ohms): 10Hz to 45kHz;
- Frequency Response @ 192kHz(Stereo only): Front Channel Out : 10Hz to 88kHz;
- Supported Output: Stereo/2.1 Speakers, 5.1 Speakers, Headphones;
- Headphone: 1 x Amplified 1/8" mini jack;
- Speaker Out: 3 x 1/8" mini jacks;
- Optical Out: TOSLINK;
- Optical In: TOSLINK;
- Line In / Microphone In: Shared 1/8" mini jack;
- Warranty: 2 Years Manufacturers Warranty;
Was [69.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Microlab SOLO8C 120W RMS - TOSLIINK - Stereo Speakers. @ £113.99 inc VAT
High fidelity tower stereo speakers with beautiful wood finish. Designed with Microlab special care and audio expertise, this series is ideal for most living room setups. Listen to crystal clear and dynamic music with this stereo pair and witness the quality in its audio drivers. High resolution and near perfect performances, simply stunning audio production quality. Stereo pair with high quality 3-way speakers that reproduces near perfect sound. Wooden cabinets for solid audio handling, and minimum distortion. Powerful sharp cone dispersion design on woofer for perfect audio experience. Comes with Optical TOSLINK and Coaxial connections for digital inputs. Side panel controls for quick easy access. Infrared remote control for convenient adjustments.
- 120 Watts of total pure acoustic power
- Natural wood finish and solid cabinets for minimum sound distortion
- Powerful 6.5” woofer, 4” midrange, and 1” tweeter drivers
- Full range sound reproduction for clearer and uncoloured listening
- Side panel for quick control adjustments
- Includes infrared remote control for easy use
- Ideal for digital multimedia playback devices such as Mp3, Mp4, Media Players, CD/DVD/Blu-ray player, tablet, smartphone, and PC/notebook.
- Support PCM sound input through Optical TOSLINK or Coaxial connections
Amplifier:-
- Output power: 120 Watt
- Distribution: 60 Watt x 2 RMS
- Harmonic distortion: 0.3% 1 Watt 1kHz
- Frequency range: 50 Hz - 20 kHz
- Signal/Noise ratio: > 80 dB
- Separation: > 60 dB
Speakers:-
- Tweeter driver: 1”
- Tweeter impedance: 4 Ohm
- Midrange driver: 4”
- Midrange impedance: 4 Ohm
- Woofer driver: 6.5”
- Woofer impedance: 4 Ohm
Interfaces:-
- Output: Binding posts
- Input: 2RCAs x 2 (AUX and PC), TOSLINK, Coaxial, RCA
- Wireless: infrared remote control
Package contents:-
- SOLO8C x 2 pcs
- 3.5mm - 2RCA cable
- Speaker interconnect cable
- 2RCA - 2RCA cable
- Optical TOSLINK cable
- Coaxial RCA cable
- Remote control
- User manual
Dimensions:-
- Product: 212 (W) x 460 (H) x 250 (D)mm
- Product weight: 16.4 kg
- Export packaging: 548 (L) x 302 (W) x 533 (H)mm
- Gross Weight: 18 kg (1 set)
- Warranty Notice: 1 Year Warranty
Was [129.95] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Logitech Z553 2.1 Speaker System (980-000355) @ £69.95 inc VAT
Logitech Speaker System Z553. Style and sound—amplified. Make a bold impression with a clean, modern design that amplifies the look of your living space. Immerse yourself in your music, movies, TV and games with a powerful, distortion-free subwoofer and crystal-clear acoustics. Plus, you can connect up to 3 devices at the same time—PCs, DVD players, video game consoles, smartphones and more. And achieve total control over volume and bass levels, with a perfectly sized control pod that fits comfortably in your hand.
• Two satellite speakers with stands
• Subwoofer
• Control pod
• 3.5 mm audio input cable
• User documentation
• 2-year manufacturer's guarantee and full product support
Was 83.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
Logitech Z623 2.1 Channel Multimedia Speakers - 200W RMS (980-000404) @ £107.99 inc VAT
Logitech® Speaker System Z623. For big, bold, 2.1 sound. THX® Certified means quality you can count on - these speakers have met strict performance standards to achieve THX certification. You'll hear - and feel - immersive audio from 200 watts (RMS) of power that brings music, movies and games to life. Multiple inputs, as well as a built-in headphone jack, make it easy to get great sound from up to three audio devices. Easy, two-satellite setup and a powerful subwoofer give you big sound - even in large spaces. And integrated controls put you in command: dial the volume and bass up or down to customise your listening experience.
- These speakers have met strict performance standards to achieve THX® certification - for quality you can count on.
- With 200 watts (RMS) of power, you can listen as loud as you want to. You'll hear - and feel - immersive audio that brings music, movies and games to life.
- RCA and 3.5 mm inputs, as well as a built-in headphone jack, make it easy to get great sound from up to three audio devices.
- Your powerful 2.1 system delivers easy, two-satellite setup and a powerful subwoofer for big sound , even in large spaces.
- You're in command with integrated controls - dial the volume and bass up or down to customise your listening experience.
Was £144.95 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Creative Sound Blaster Audigy Fx OEM (CL-30SB157000001) @ £18.95 inc VAT
The perfect Sound Blaster upgrade The Sound Blaster Audigy Fx is a half-height sound card that's powered by SBX Pro Studio technology. It instantly converts your system to a 5.1 entertainment system that delivers cinematic surround sound - perfect for bringing out the best in your movies, music and games! The Sound Blaster Audigy Fx also features a 24-bit 192kHz digital-to-analog converter (playback), 106dB SNR and a high-end 600-ohm headphone amplifier for studio-grade monitoring. Interchangeable full-height and half-height metal brackets are included to give you the flexibility of installing the sound card in small form factor desktop PCs.
Enjoy multi-channel cinematic sound The half-height PCIe sound card is just the perfect size for your home theatre PCs. You can now upgrade your cinematic experience with Sound Blaster audio fidelity. Sound Blaster Audigy Fx comes with 5.1 channel outputs so you can connect to your existing multi-channel speakers with ease.
Independent input sources Sound Blaster Audigy Fx comes with independent line-in and microphone connectors, which allow you to plug in two different audio sources to your PC.
Specifications:-
- Signal to Noise Ratio: 106dB
- Sound Output Mode: 5.1
- Standards: SBX Pro Studio
- Sample Rate: 16-bit to 24-bit playback sampling rates: 44.1, 48, 96, 192kHz‚16-bit to 24-bit recording sampling rates: 44.1, 48, 96kHz
- Compatible OS: Windows Vista‚Windows 7‚Windows 8
- Package Type: OEM
DAC Data Width : 24 bit
Interface: PCI Express x1
Connectivity: Headphone/Front Out: 1 x 3.5mm jack‚Rear Out: 1 x 3.5mm jack‚Centre/Subwoofer: 1 x 3.5mm jack‚Microphone In: 1 x 3.5mm jack‚Line In: 1 x 3.5mm jack
Special Features: 5.1 PCIe Sound Card with SBX Pro Studio‚Enjoy multi-channel cinematic sound‚Independent input sources‚Headphone Amp up to 600 Ohms‚24-bit 192 kHz Stereo Direct
Was £24.95 Inc. VAT
Only £18.95 inc VAT.
ORDER NOW
**B Grade** Beyerdynamic MMX 300 Premium Gaming & Multimedia Stereo Headset @ £149.99 inc VAT
Premium Gaming / Multimedia - Headset
A class like the digital MMX 300 premium headset might have been unknown to gaming fans: A Hi-Fi capable professional headset derived from the private aviation and perfected for use in noisy cockpits, has been adapted to the special requirements of extended gaming sessions.
The MMX 300 exceeds all expectations of ambitious gamers regarding performance, sound and comfort.
Equipped with an intelligent USB converter, which provides a mute button for the condenser microphone and a volume control for quick access during the game, the headset becomes via plug & play a guarantee for maximum gaming experience. Designed for those, for whom the best is barely good enough at home or on the “on the road”. The flexible headband construction allows playing for hours without fatigue; circumaural ear pads snuggle almost unnoticeably to the head of the player. This high-end headset also provides analogue connections to connect the MMX 300 to other devices to prove its qualities as a hi-fi headphone.
Specifications:
• Transmission type - Wired
• Headphone design (operating principle) - Closed
• Headphone impedance - 32 ohms
• Headphone frequency response - 5 - 30.000 Hz
• Nominal sound pressure level - 96 dB
• Polar pattern for microphone - Cardioid
• Transducer type for microphone - Condenser
• Construction - Circumaural (around the ear)
• Cable & plug - 2 x 3.5 mm (1/8") jack plugs & USB converter
Features
• Digital premium headset with carbon design
• Cockpit tested audio components with impressive speech reproduction in hi-fi quality
• Mobile high-end sound at LAN parties or at home
• Sophisticated sound card with volume control and microphone mute function
• Analogue interfaces to connect the headset to the sound card directly or to use it as a hi-fi headphone
• Closed design of the headphone
• Excellent attenuation of ambient noise (approx. 18 dBA)
• Ergonomic design for superior comfort
• Professional, noise compensating condenser microphone for clear and precise voice transmission
• Rugged headband made of spring steel with soft, replaceable ear and headband pads
• Supplied with practical carrying case
• “Made in Germany” with a 5-year warranty
Originally sold at £233.32+VAT
Was [OLDPRICE] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
**B Grade** Wavemaster TWO Stereo Speaker System with integrated AMP - Black @ £149.99 inc VAT
Stereo speaker system with integrated amplifier for connecting your iPod/iPad/iPhone/Mac, TV, PC or any other audio source.
Brilliant and powerful audio reproduction, clear design, valuable material and superb finish.
Signal sensor for automatic on/standby, connect 2 audio sources simultaneously (Dual Audio Source).
- Tweeter: 2,00 cm with silk dome and ferrite magnet
- Woofer/midrange: 13 cm with Kevlar™ cone and ferrite magnet
- Amplifier: 2 channel, integrated
- Output power (RMS): 2 x 30 Watt
- Frequency response: 45 - 22.000 Hz
- Cabinet: wood with piano paint, 2-way concept with bass reflex technology
- Controls On/Off (main), On/Standby/Volume, treble and bass control
- Auto Switch: signal sensor for automatic On/Standby
- integrated power supply (230/115 Volt switchable), standby consumption < 0,5 W (230V)
- Connectors: 2 x Line-In (3,5 mm und RCA / Dual Audio Source), USB power, AC power
- Dimensions (WHD): 180 x 256 x 205 mm
- Colour: Black
Originally sold at £191.66+VAT
ORDER NOW
Features
Only £9.95 inc VAT.
ORDER NOW
- Distortion: <0.5
- SW: 30Hz ~ 130Hz
ORDER NOW
- Distortion: 0.5%
Was £23.99Inc. VAT
ORDER NOW
Power up
Gear up for victory
Go Pro
96kHz;
ohms): >105dB;
ORDER NOW
Amplifier:-
Speakers:-
Interfaces:-
Package contents:-
- SOLO8C x 2 pcs
- 2RCA - 2RCA cable
- Coaxial RCA cable
- Remote control
- User manual
Dimensions:-
ORDER NOW
• Subwoofer
• Control pod
Was 83.99 Inc. VAT
ORDER NOW
ORDER NOW
Specifications:-
- Package Type: OEM
Was £24.95 Inc. VAT
ORDER NOW
Specifications:
Features
ORDER NOW
- Colour: Black
ORDER NOW
