Where to start! So we purchased our new house back in December last year and eventually moved in mid-January. Prior to moving in we had to have the whole house re-wired, new boiler, re-do a section of the flat roof on the utility and re-decorate the whole house. Ideally we should have had the kitchen done at the same time but funds did not allow, we finally had the new kitchen installed last month. Now our attention has moved to our garden, we didn’t really have a garden to speak of at the old house; just a paved back yard and a grassed area out the front of the house. We’ve recently had a new 5ft feather edge fence put up the left and right hand side of the garden; which matches the fence at the rear of the garden. (This has made sure the garden is dog proof as ours is a proper escape artist!)
Below is a basic paint drawing of the garden as it stands now, the reason for this post is some advice on what to do with the summer house. The dimension are 19’8”ft x 7’7”ft, you’ll see from the pictures the double door isn’t up to much at the moment (we’re getting a quote on a new one). The windows are just basic with a single pane of glass, I think there just three that are missing glass. At some point the old owner who I presume built it has started to insulate some of the walls (see pic below). There’s also some sort of fuse box with trunking and plugs running along the back wall. I’m getting the electrician back soon to try and find where the underground electric cable goes to as I cannot locate it. The roof is half wood which is felted (back) and half plastic (front), as far as I can tell it’s water tight what with all this rain recently I cannot spot any signs of water on the floor or damp patches on the roof.
So we’ll hopefully have a new door in the next couple of weeks and I’ll put some replacement glass in the windows that are missing. I guess my question to you all is how would you go about insulating it? Would you do all the walls? Put a ceiling in the roof? I have basic DIY skills but would this be a task a novice could pull off? We could get someone to do it for us but I really want to have a go myself and save on paying for the labour. We’ve probably got a budget of £1,000 that’s for the new door, insulating/new interior walls and electrics. The end goal is to have a bar area in there and some sort of table and seating.
Looking forward to your opinions!
Thanks!
Thanks!
