Summer temps advice needed plz
23 Nov 2009
North Leicestershire
well it's getta kinda hot my house is like a oven.
cpu is hitting 56
gpu is hitting 79
i can bring those down a bit by wacking my 16 inch fan at the intake side of my haf 932 but it's kinda noisey.
Should i be worried at all or think about lowering the clocks on the gpu and cpu
yeph my temp went up also, i just took of the panel and the temp started to go down but that was on a load not idle....hope for your sake that is not idle, if so there is something wrong with your cooling method
My idle temps for my 3.2ghz overclocked i7 are 44-48 for the cores and the graphics are idling around 35-40 degrees depending on case position, so yes the temps are higher than normal, my normal idle on the cores is 35-40 and the graphics 30-35 so ambient air temp goes up so does your idle temps
