Summer temps.
20 Oct 2002
North West
Today my E6300 is at 51c idle and 55/6 during a game of 2142.
E6300 2.8 @ 1.4318v
Damnit! I have a lian-li V1000B+/Arctic Freezer 7. I have the two stock lian fans and a sycth kama bay cooler.
Hopefully my system will keep going through the hotter days :/
Just had Orthos on (two copies) for half an hour...temps where around 58/60. Not too bad at all.
E6300 2.8 @ 1.4318v
Your vcore seems very high for that overclock, most will do 2.8 at around stock volts (1.325). Are you able to reduce the vcore without affecting stabilty?
E6300 2.8 @ 1.4318v
The Artic cooler couldn'y keep my Amd X2 4400 cool last summer and it was only overclocked to 2600. I ordered a Scythe Ninja 120+ and that cured it. since moving to Intel Core 2 I ordered the SunBeam Tuniq Tower and its coping well though the temps are creeping up as the summer gets warmer :eek:
Sadly no, stock doesn't work.
Only a 4c increase in temps while on full load with the graphics card kicking out a lot of extra heat aswell? Sounds abit strange to me. The idle temp is the only thing that seems abit high the load temp is fine if accurate.
