Summer temps...
20 Oct 2002
North West
Just playing WoW at the moment - around 60-80% load and getting:
56-57 on both cores and 59 oh chipset.
Not really too bothered...but summer's definately here! I'm using an AF7 pro and lian-li 1000B+ with scythe kama bay.
Yep getting similar with my setup, was idle around 35c now up to 42c. bedroom was around 28c.
Actualy turned my AC on which helped a great deal.
Rob
Room temp 39c :cool: , im stuck in my attic with no windows :(
X2 4400 at stock speeds runnin at 48c, mobo 41c.
My case is a ThermalTake Kandalf with all the fans in:)
my idles up by about 2-4 degrees but as its not clocked not exactly worried, the system was stable at 60+ degrees under load when I was playing around with overclocking a few days ago so my current load temps of 50 degrees in a sugo are fine :)
My temps have definetly shot up GPU seems to be handling it ok so far :) , CPU temps suffered the most and have shot up by around 7c :(
