- 2 Aug 2010
- Egypt/ Surrey
This is going to hopefully be finished before September and I plan to take as many photos as possible as I go (with my iPhone or my neighbour’s DSLR). This project should keep me busy during the summer months at least because when school starts I have no time to make any modifications
The current build state (16.7.17)
Previous build state:
The current build is;
Corsair 900D
I7 4790K @4.4ghz
Asus Maximus Hero
Hyper x 16GB (2x8)
Palit Super Jetstream 980
XFX 850 Pro
1 SSD
2x 4TB 3.5” drives
1x 2TB 3.5” drives
24” BenQ 1080p monitor (Upgrading soon)
Watercooled CPU loop
Ek 400 Reservoir/ D5 combo
360 XSPC 45mm
Corsair SP120s
BeQuiet 2200rpm x2 (Not quiet at all considering the name!)
6 Fan controller with annoying blue LEDs (This is going to a new home)
The current build is a mess. The fluid has changed from Pastel red to a murky colour which has been neglected for far too long. So it needs changing. I will be removing, flushing and salvaging parts for the update. I will also lose the extra 2TB as it really isn’t necessary right now. I am expecting a considerable amount of dust.
Hond 3.0
Edit: not sure why it appears so skewed :/
The name is inspired by my D&D character, with a split personality. His good/evil nature has led to various nicknames and Hond 3.0 is the newest nickname which seems to have stuck with him. Anyways onto the interesting stuff…
The new parts list will involve some ColdZero parts. Here is the new parts list:
KFA GTX 1080 Ti FE
Watercooling
EK Water Blocks 1080Ti Acetal -No backplate!
EK Water Blocks EK-Supremacy EVO - Acetal+Nickel
XSPC clear tubing
Bitspower Fittings
EK Water Blocks EK-CoolStream PE 480
EK Water Blocks EK-RES X3 - TUBE 250
Mayhems Pastel Red
ColdZero Parts
Full Motherboard Tray
Front Fan Cover -Full
Lightbox- White LEDs
GPU block
PSU plate
Case backplate
Other stuff:
Custom extension cables by Pexon
Thermal Grizzly Aeronaut High Performance Thermal Paste
XSPC Heavy Duty Hose Cutter (0-25mm)
Fan splitters
Phanteks PWM Fan Hub
10m Network Cable
Dremel
Drill
This was only based on stock at the time of ordering. I plan to upgrade to rigid tubing in the future so will use that opportunity to get things co-ordinated. I will also be selling the 980 to recoup some funds. I live and work in Cairo so ordering parts is a nightmare as some delivery services refuse to ship here (Looking at you OCuK) but I understand why and the costs/ logistical problems involved. I typically order them from OCuK to the UK and then fly them to Egypt in my luggage. Two bags with Business class
The plan is to strip out the case entirely and give it some cleaning. I hope to remove the 5.25” drive bays and install a midplate of sorts. All parts have been ordered except for the ColdZero parts which I am currently discussing with them but I hope they come good.
Corsair 900D
I7 4790K @4.4ghz
Asus Maximus Hero
Hyper x 16GB (2x8)
XFX 850 Pro
1 SSD
2x 4TB 3.5” drives
1x 2TB 3.5” drives
360 XSPC 45mm
Corsair SP120s
Hond 3.0
KFA GTX 1080 Ti FE
Watercooling
XSPC clear tubing
Bitspower Fittings
Mayhems Pastel Red
ColdZero Parts
GPU block
PSU plate
Case backplate
Other stuff:
Fan splitters
10m Network Cable
Dremel
Drill
