Hi all
this is a car audio topic but I think HiFi brains may be more beneficial to me solving it. In short I think I need to combine two stereo feeds into one combined feed, this is called summing? I don’t want to use a simple RCA Ycable as I suspect interference/back feeding but would be happy to be proven wrong.
Basically I want to fit a subwoofer to my BMW OEM stereo. I have done this numerous times, so “know what I am doing”. The last two BMWs I upgraded all work, but I want to improve the sound, as the subs are only getting a low-frequency feed (duh), and I’d prefer to creep into the low-mids as well as sub frequency.
background: the only way to install them is to take a high level speaker feed and convert to low-level for the amp to drive the sub, that’s all pretty normal. However in BMWs you can only take a feed from the speaker wires after the oem amp has processed it. In my cases the car has an oem subwoofer, and so taking the oem sub feed and sending it to my sub amp works ok. However, I think I’m only getting the pre-crossed (filtered to sub bass) and I’d prefer a slightly higher low-mid bass (or sub amp adjustable) crossover.
I assume (need to check) that a door speaker has the sub frequencies already filtered out, so no good taking a feed from those instead (would they maybe get the full range even though a sub is oem fitted?).
If that’s true, the last option i see is taking the oem sub and door speaker feeds, combining them and then feeding that to my sub amp.
And it’s this summing/combining I need help with. Firstly is my theory ok? Secondly there seems to be a total lack of affordable product to do this. Wiring diagrams seem to suggest building a summing box like this just requires a few resistors, but summing boxes are £hundreds.
any tips/advice or feedback to steer me better?
thanks
thanks
