Sun blind
I'd first see if there are any "genuine" ones from the car manufacturer.
The ones I had in the back of my 330d were made by BMW and clipped to the window frame completely covering the entire window, meaning that no matter where the sun, or the position of rear passengers head, the sun didn't blind/disturb at all.
That does include the rear windscreen too, I imagine if you can get the side ones on their own it will be far cheaper.
I ended up purchasing a set from vanstyle.co.uk, cost about £90 i think, after going through a few halfrords blinds and a mothercare set too, these are much better and cover all of the window, would recomend them to anyone, even if they are bit expensive.
