They are normally screws rather than bolts on the Sun cabinets.
Not sure what size they are as I usually used the supplied screws when installing new kit.
One word of advice though, the screws are normally really soft and damage easily so take it easy with them
If you can get 10-32 size screws, do. M5's are obviously much easier to get hold of, but in my experience you'll have much more problems with screws getting stuck etc if you don't use the right size.
