SupCom - Dual Core Usage
29 Jun 2006
Manchester
well ive had supcom for a while and just got new processor/gpu a 5000X2 and an 8800gt, i also have 2gb ram.
but if i have quite a bit on screen the game slows (when zoomed in) to a very low fps, which i dont think it should as i have a reasonable setup. so i turn down the graphics, and its the same, so i guess its processing power not doing it. i thought a 5000X2 would be enough to run it well so i press ctrl alt dlt so it can monitor it for a while. here what it showed.
it doesnt appear to be utilising both cores, is there a reason for this? because at the minute the game is running worse than my single core 3800. which i aint very happy about
ive fully patched the game, so not sure how to fix this issue, any help appreciated :)
not that im aware of, ill install in then see how it goes
edit: cheers phillydee ill check that out as well :P
used both the amd optimiser and the supcom core maximiser and its running a lot better, and the load is spread over the 2 cores, thanks guys :)
