** SUPER FLOWER GUN METAL GREY POWER SUPPLIES & BRAIDED CABLE KITS NOW IN STOCK **
OcUK Staff
26 Nov 2014
Stoke
Finally, after a long time in the works, we're happy to be stocking what I believe is the worlds first retail gunmetal grey power supplies. Initially we have two models, 850W Platinum, and 550W Gold. Moving forward we'll expand to other wattages. These look really nice in the flesh and I've fairly certain I'll be using the 850W Platinum when I upgrade next!
Added to that we've also taken initial stock of the Super Flower braided cable kits. These are fully compatible with the Leadex Gold and Platinum series up to 1300W, and both Golden Silent fanless units. They are nice quality, fully braided cable sets available initially in Black, Red, Black/Red & White, with other colours following in the future.
Stock is limited on the cable kits in particular so if you've been waiting for these, I wouldn't hang around! All are in stock and available now!
Super Flower Leadex Platinum 850W Fully Modular "80 Plus Platinum" Power Supply - Gunmetal @ £127.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 850W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-850F14MP Black
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 2 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Only £127.99 inc VAT.
ORDER NOW
Super Flower Leadex GOLD 550W Fully Modular '80 Plus Gold' Power Supply - Gunmetal @ £76.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 13.5cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features
- 80 PLUS ® Gold Certified, 87%, 90%, 87% Efficiency At 20% 50% 100% Rated Load
- Small Size PC Case Friendly (165mm length PSU chassis)
Specification
- Type: ATX
- Maximum Power: 550W
- Fans: 1 x 13.5cm Two Ball Bearing Fan (automatic control, semi-passive)
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage: Full Range - 100V~240V
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
- Protection: OVP/OCP/OPP/SCP/UVP
- Dimensions: 165mm(L) x 150mm(W) x 86mm(H)
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 3x 6+2-Pin-PCIe
- 7x SATA
- 4x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £76.99 inc VAT.
ORDER NOW
Super Flower Braided Cable Kit - Red @ £59.99 inc VAT
Finally, owners of Super Flower Leadex and Golden Silent Power Supplies can customise their systems with compatible braided cable kits. These high quality kits are available in a variety of colours to suit your preference and are expertly textile braided for durability and flexibility. Included are a wealth of connectors to cover your needs, and all cables come with the crystal tube connectors to work with the LED connectors on the Leadex series.
Specification
- Material Sleeving: Textile
- Colour: Red(sleeves), black (male)
- Compatibility: Power Supplies (unrestricted): Super Flower Leadex 80 Plus Gold (550/650/750/850/1000/1300 Watt), Super Flower Leadex 80 Plus Platinum (550/650/750/850/1000/1200 Watt)
Compatibility Power Supplies (restricted), Super Flower Golden Silent 80 Plus Gold Fanless Power Supply - 430 Watt, Super Flower Golden Silent 80 Plus Platinum Fanless Power Supply - 500 Watts (These power supplies are part-modular, therefore the fixed cable can not be replaced.)
Cable List
- 1 x 20 + 4-pin ATX12V / EPS12V (580 mm without plug)
- 2 x 4 + 4-pin ATX12V / EPS12V (690 mm without plug)
- 4 x 6 + 2-pin PCIe (590 mm without plug)
- 1 x Dual-6 + 2-Pin PCIe (1/2 terminal:. 590/720 mm without plug)
- 2 x Triple-SATA (1st / 2nd / 3 Connection:. 550/680/810 mm without plug)
- 1x Triple Molex (1st / 2nd / 3 Connection:. 550/680/810 mm without plug)
- 1x Dual SATA with dual 4-pin Molex (1 SATA / 2 SATA / 3 Molex/ 4 Molex connector... : 550/680/810/940 mm without plug)
Only £59.99 inc VAT.
ORDER NOW
Super Flower Braided Cable Kit - Black @ £59.99 inc VAT
ORDER NOW
Super Flower Braided Cable Kit - Black/Red @ £59.99 inc VAT
ORDER NOW
Super Flower Braided Cable Kit - White @ £59.99 inc VAT
ORDER NOW
Cables? ololol....Finally !
+1
BTW, any news @The Thermal Grizzly Conductonaut ?
We want it !
Ordered the reds, along with 1 24pin comb, 2 8pin combs and a 6pin and some velcro wrap. Looking very forward to this lot, My cables are a mess atm.
Just as PSU's start to get sexy..case designers cover them up.
Yes, PSU shrouds are so unthoughtful! Luckily people like Phanteks aren't following the trend. This will look lovely in a gunmetal Evolv ATX :) I think a bundle deal may make an appearance in the next few weeks!
You say this and the new case unveiled by Phanteks at CES, the P400, has it completely covered! :p
Superflower PSU simply the best!!
Kits are looking decent too Chug. These are a solid option if you don't want to braid the lot yourself.
Great to see the cable bundles released. I'm not a fan of the flat style cables that some psu manufacturers use for some cables. Very well priced too, iirc I paid a fair chunk more for a set for my old corsair hx850.
Would love to see some comparison to Pexon Telelios cables ;)
Do these cables hold shape?
Also OT question, are you getting Thermal Grizzly Conductonaut any time soon ?
Wondering about this too, I've got a few custom extension cables made from teleios sleeving. Bit stiff, paracord braided cables like bitfenix ones tend to hold bends better.
