Spec -
CPU Name String: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPU Name: Intel Core 2 Quad Q6600 (Kentsfield)
Platform: ASUS STRIKER2 EXTREME bios 0704
CPU Speed: 2400.00MHz (266.67 x 9.00)
RAM
OCZ 4GB DDR3 PC3-10666C7 1333MHz Platinum (2x2GB)
PSU
Enermax Galexy DDX 1000w
OS win vista 64bit
The system is water cooled (cpu + fusion block) with 360rad / big ass pump etc, with additional fans on the rest of the system where needed, case is a Silverston t70J
using the default level up in the bios i cant get my system to be stable in windows at anything above the stock level of 2.4gig im really stupid and have read many a guide but i simply dont get the maths or what needs to be changed. I suspect i should be able to get 3.6Gig out of this system shouldnt i?
Can any one walk me step by step through setting up the bios correctly, i have a spare laptop with msn/voice coms if some one is willing to help.
hoping someone can help me.
look forward to your replies.
PS CoreTemp is reading tempreture at above stock values at:36c 37c 31c 32c do these look right?
Sunburn
RAM
PSU
OS win vista 64bit
Sunburn
also guides say to keep memory linked where as you suggest that it should be unlinked?
