Superdrive help
6 Oct 2019
Hi please bear with me, I am trying to get a Superdrive (model number A1379) working on a 2012 Macbook Pro this drive works perfectly on a 2009 Macbook Pro running El Capitan, the drive is not faulty.
I have tried High Sierra & El Capitan to no avail, I keep getting the error message 'USB Device Not Supported'
Been a Windows user, I cannot figure this one out, anybody help? It should be plug and play?
MBP 2012s have a built in drive so Superdrives are not supported (some models are though mind). There is a terminal command I think which works, will see if I can dig it up.
