Superflower 1200W VGA cables
5 Oct 2009
I have noticed that my Superflower 1200W has PCIe/VGA cables that have two connectors on the end. I currently only use one per connection on the cards meaning I am using four cables and this creates a lot of mess near the gcards.
So - can I use one cable for one card or should I buy extensions cables?
:confused:
Sorry to ask mate as I am pushing my luck - any chance of an upclose shot of the GPU power area? I'd like to understand how you have hidden the cables
I don't have that built up anymore, I'm afraid... Everything is currently sprawled out on a test bench.
It's a corsair 500R and they basically went through a grommet, behind the mobo tray and back through another set of grommets.
Your 540 should have plenty of space to hide cables.
Ah I see
Have you got the first going into the bottom card and the hang-off into the second card? Or does one cable supply one card?
Hopefully that make sense
