Hi all,
had this PSU since 2014 & its been loud since then.
In Auto mode i found it extremely loud.
In Eco mode its still the loudest thing in my PC.
The Noise is Like a rattle, or a Fan spinning so slowly it sounds off balance, (or bearing gone)
The issue is the Fans not spinning. The noise is annoying me now as this rattle although is very quiet is the loudest thing in my PC.
On the desktop my Fans do not spin & can hear it if listening carefully 1-2M away
What do you think i should do?
not sure if still in warrenty. Is it possible Its faulty?
