Superflower 650w modular - mains plug
11 Aug 2014
Hi,
Could any of you chaps who own the subject PSU please spec me a mains plug adapter?
Is there any particular ones to avoid, or has anyone found what they consider the perfect plug adapter?
Or
I seem to recall seeing something mentioned about a kettle lead?
Anything in particular I need to look out for if this is a viable option?
Thanks in advance
Hi Stulid,
Correct, purchased from OCuk and supplied with EU plug kettle lead.
EDIT: Issue resolved. New lead in the post.
Hi,
So to be clear..
You bought this PSU and it has a euro plug kettle lead only supplied?
You purchased from OcUK?
Just as a follow up, I purchased a 650w Superflower (see sig) from OCUK in July and it also only came with a 2 pin European Kettle lead.
Wasn't very pleased TBH.:mad:
If you never received a UK Mains Cable please contact us and we will send you one out.
I have sent an email out too, to ensure future orders have these included. :)
That's ok chief, not bothered about it now, I had 2 or 3 spare anyway.
The annoying bit was having to rummage around in the loft looking for one...spent 15mins up there before I remembered I'd shifted them into the garden shed a few months earlier.:p
