Superflower 750w 80+ Gold
I would probably go for 850W for 780ti sli and i7 4770K. Are you running a 4K monitor ? As that is a pretty hefty gpu setup.
Also Z97 is just around the corner so you might be better waiting. They are supposedly due around the 11th of this month, with cpu's to follow after.
It will be fine if it is one of their systems, otherwise they wouldn't sell it. Hard drives don't use a lot of power, so adding a few more won't pull more than 15W each.
If you feel you want a bit of extra headroom for overclocking etc, you can always give them a ring an tell them to change the psu for an 850W. Something like the EVGA 850W or Seasonic Evo 850W.
YOUR BASKET
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £109.99
1 x Seasonic M12II EVO Edition 850W '80 Plus Bronze' Fully Modular Power Supply £95.99
Total : £220.08 (includes shipping : £11.75).
If OCUK sells it as part of a bundle i guess it's enough power. It's not even modular though and personally i would want a bit more headroom. Ask them if you can upgrade to the EVGA Supernova G2 850w which is fully modular, built by Superflower and has a whopping 10 year warranty.
