SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply
OcUK Staff
12 Apr 2008
OcUK HQ
Recently this power supply has been winning quite a few awards! - I can see why, you can trust the brand, you can trust the products, not only that the products look great and have fantastic reliability and great performance. Everything you want and need from a PSU!
If you are looking to buy a new PSU, we recommend Super Flower as they are phenomenal!
See the reviews and overviews here from some of the media:
http://www.bit-tech.net/hardware/psus/2014/06/20/550w-650w-psu-roundup/10
http://www.hardwareheaven.com/2014/09/super-flower-leadex-gold-650w-psu-review/
http://www.play3r.net/reviews/psus/super-flower-leadex-gold-650w-review/1/
http://www.eteknix.com/super-flower-leadex-gold-650w-modular-power-supply-review/1/
Also, don't forget you can buy this PSU from us here:
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black @ £77.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 650W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@22A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Give Super Flower some support, and 'Like' them on Facebook. :)
https://www.facebook.com/superflowerpsu
Looks a good price - I see it has 5 Years warranty but how is this handled? Where would it need to be sent to throughout its warranty period?
Thanks.
