Superflower Leadex Gold 850w and 1300w same physical size?
17 Jan 2007
Kent, UK
Hi, a quick question for you guys. Are the Superflower Leadex Gold 850w and 1300w PSUs the same physical size or is the 1300w any longer?
I ask because I currently have the 850w and it's quite a tight fit with the fan I have on the floor of my case and if the 1300w is any longer it might not fit without removing the fan.
Thanks,
Ross
Yes, my 1000w died and so I replaced it with 850w, because I decided that was all I needed. In fact, I was the person that wrote a review explaining about the size difference on the OcUK product page for the Superflower 850w Black.
Ah yes, I didn't notice that on there. Thanks for that, would have been annoying to find out after buying it. Not a massive problem, probably just means I'll have to downsize the 140mm fan I have on the case floor to a 120mm to give some extra space.
