Hi there
Superflower are flexing their muscles and have won the group test over at Bit-Tech, have a read for yourself here:-
Bit-Tech PSU Group Test!
Superflower are one of the best OEM's on the market, soon we shall be seeing some interesting units from them such as 1600W Titanium model and 2000W models as well.
We are also now using Superflower PSU's in our system builds.
To celebrate we have reduced prices on nearly all our models, view the range:-
Superflower PSU Range!!
Here is the unit which won the group test:-
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black @ £77.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 650W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@22A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £77.99 inc VAT.
ORDER NOW
Some higher wattage versions of this model:-
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black @ £86.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 750W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £86.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black @ £99.95 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 850W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black @ £139.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £139.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black @ £155.99 inc VAT
Features:-
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1300W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable Yes 100% modular cable design
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
- Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=367
Only £155.99 inc VAT.
ORDER NOW
Remember to also check out the Platinum range and if your a system integrator the Golden HX models offer the same 80+ Gold standard and same quality/reliability at a much lower price point as they are not fully modular. We also have the Amazon range as well which are ideal for home/office PC's also meeting 80+ Bronze standards.
If you are an SI or business/corporate customer we offer attractive discounts for those buying in volume so get in touch with our B2B/Trade sales team for a quote.
Features:-
Speciication:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Features:-
Speciication:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Features:-
Speciication:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Features:-
Speciication:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Features:-
Specification:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
