Superhub 2 issues
2 Jul 2012
Hey guys,
Just installed a super hub 2 the other day (Virgin Media) and all seemed to be working fine unitl I tried to play a MKV file from my N54L.
If my PC and N54L are both plugged into the super hub 2 then the video and audio stutter constantly.
I then plugged both the PC and N54L into the old superhub and the video played fine with no stutter.
I then tried having the PC plugged into the superhub 2 and the N54L into the old superhub with a patch cable between the 2 and that worked fine also so it is not liking having both connected directly for some reason.
Any ideas what the problem may be or anything I could try?
I don't have any spare sockets for a switch to plug into so didn't want to go down that route unless I have to.
Thanks in advance.
SM
