My Board is a superMicro Dual Opteron effort. This is the very one :-
http://www.supermicro.com/Aplus/motherboard/Opteron6000/SR56x0/H8DG6-F.cfm
Anyway... I have a few issues with crashing at stupid times and in the quest to cure this, my next step is to make the chipset as cool as I can.
The board has 2 large chipset coolers on it, plus one smaller, slightly taller cooler, just above the top PCIE slot.
The 2 large flat ones are nearly useless, the alloy they have used is clearly not very efficient, and for such an expensive Motherboard, I find that to be an insult for them to cut such corners and not have at least better alloys, or hell, even copper.
Now, I am seriously considering simply buying a flat heatsink thats big enough, but then drilling a couple of holes into it to match the alloy ones and then using the copper heatsinks instead. I have seen a few options that look like they will do the job.
Similarly, there are 2 smaller square heatsinks just below these larger ones, however there is plenty of options for these... I just wonder why one is black and the other uncoloured/grey?
The one just above the PCIE slot however is one that I dont know what to do about?
Does anyone have an ideas, other than simply trying to get a good airflow over it?
